跳转到主内容
型号 A1059 或 A1099 / 20, 40, 或 60 GB 硬盘 / 中央转盘为触控激活
227 个问题 查看全部
问题已关闭
click/touch dial will not work
The click/touch dial will not work. The last time I used it I paused it and it turned itself off. When setting in a cradle (i.e. a unit with its own speakers or a unit to play the iPod through my home audio system), the iPod works using the remote controller. The remote controller I own do not have a full range of features; therefore, I can only play/pause/forward/reverse the iPod. I cannot change play lists or access any other feature, including the menue. Do you know what might be wrong and what it might take to fix the problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
First, try restoring the iPod. If that does not work, try opening the iPod to see if there is any damage or corrosion. I have also had it that once I opened the iPod, detached and reattached cables, the problem goes away.
If still nothing, try another click wheel. If that still doesn't help, then the final thing it could be is the logic board.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,176
