跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
New battery is not charging. iPhone's working perfectly otherwise.
I put a new battery in my iPhone 7 Plus. Install went smoothly. All connectors back in place solidly. But it won’t charge…no lighting bolt. What can I test? What should I look for? {I’ve tried various chargers and cables that I know work, by the way.) Could the battery be bad? In Settings the ‘battery health” is described as 100%.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Where did you buy the battery from? There could be a possibility you knocked the lightning port connector loose so open it back up and inspect that. That may need replacement as well.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
tbeaty 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 17
