跳转到主内容
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
20 个问题 查看全部
Why won't this thing turn on?
I bought this laptop to refurbish it. I got a new display, top palm rest along with keyboard, aftermarket battery, and aftermarket charger.
My first time fully taking it apart and replacing damaged parts, it worked. I was able to login and take care of some stuff.
I didn’t adhere to the battery and I also forgot to install the backlighting cable. I went to finish it off by fully installing the battery and reconnecting that wire. Now, the MacBook will not boot.
All I get is the fans spinning when it’s plugged in, nothing at all when it’s not plugged in. I got it to work for a second but it booted up playing the sound and the cut out again and did the same thing on repeat.
Now I can’t even get it to play the boot sound anymore. I have taken it apart again and reassembled it. Still the same thing.
When it’s plugged in, I can hear the fans going higher in RPM and then lower like in a pattern. Not sure what’s going on. I already tried resetting SMC and trying with and without battery. If it’s not plugged in, the laptop does nothing at all.
Please help LMAO! I’m going nuts.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
What happens when you disconnect the keyboard backlight ribbon cable?
完成的
same thing. I actually started to get it sorta working last night. It keeps playing the bootup sound but does not show the logo and then cuts out and repeats that process. So it seems like something is causing a problem?
完成的
添加一条评论
1个答案
Sorry, I think its time to find a new logic board
这个答案有帮助吗?
得分 0
3条评论:
nothing else you think I can try?
完成的
Sorry - Thats it
完成的
@danj Got it! I'll get the logic board checked out by a company I know that's very good for that kind of thing. Thanks!
完成的
添加一条评论
添加你的答案
Dario daja 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 72
