跳转到主内容
发布于2017年6月,iPad Pro 10.5寸替代发布于2016年的iPad Pro 9.7寸。
145 个问题 查看全部
My Ipad Pro 2017 bent. I bent it back and now it won't charge.
My Ipad Pro 2017 got slightly bent on the right edge (looking at the screen) while it was in a case. I noticed when the screen looked like it was being pushed on in that area, the bend wasn’t noticeable until i looked at it on the side.
I bent it back gently by hand until the screen pressure spot was gone, and now the Ipad won’t charge. The battery is discharging as usual, just nothing happens when I plug it in.
Is there some specific connection that could have been broken or disconnected by a slight bend forward and back in the center of the right edge?
I’ve tried different cables, different AC adapters, different wall plugs, and cleaned the port. This happened right after I bent it back so I’m pretty sure that’s the issue.
Here are pictures of the bend:
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
you might get away with having the charge port replaced but looking at where the bend is lots could have happened, a chip could have lifted. A board-level repair shop might be able to deal with it. (ipadrehab)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Dublin Nichols 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 239
