It's posible to replace the usb ports?
I want to replace the usb ports cause they stoped working
Replacing the physical ports is possible. But its also likely you have a deeper issue within the ports logic on the logic board.
You really need to run the onboard diagnostics as well as check the port using a USB-C power meter like USB-C Power Meter
这个答案有帮助吗?
Thanks Dan, it's because one day suddenly the ports stopped working, the mac it's out of warranty so I wanted to try replace them and give it a shot, instead of buying a new logic board. On this day I can't even find one. But i'm can't find a replacement guide or video exclusively for the usb-c board replacement
@josevasquez - How many of the ports are dead? Are they together on the same side?
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 66
