Battery is full but Mac says 'Replace Now'
Hi
I’m using a third party replacement battery, after a previous replacement battery bloated. It worked great for a few days, and I put the Mac to sleep.
A few days later…
- The side indicator doesn’t light up at all, and it won’t power up
- On charger, coconut battery says it’s 100% (capacity 7188), and side indicator button shows full power.
- Coconut battery says the battery condition is poor, and the Mac says ‘replace now’
- When I unplug the charger, the Mac goes dead immediately.
Any idea what’s wrong?
Can you post a snapshot of CoconutBattery so we can see what its telling you 在已经存在的问题里加入图片. Make sure the MagSafe charger is plugged in and the system is under charge.
Its possible the battery is bad or something more I would need to see the snapshot
由 Dan 完成的
Thanks Dan. Uploaded a pic of the coconut battery reading.
由 clim 完成的
@clim57 - I guess I'm a bit confused the MagSafe LED is not lit? Or is it Amber or Green?
But the onboard battery checker shows 10 bright little Green LED's when you press the button. Is that correct?
由 Dan 完成的
@danj the MagSafe Led is green when I plug in, and the onboard battery checker’s 10 little green LEDs light up.
That’s correct.
由 clim 完成的
I suggest try resetting SMC. SMC: press left shift, left control, left option, and press the power button all at the same time. The Magsafe 1 light should change from amber to green than back to amber if done right.
由 Anthony Talcott 完成的
