跳转到主内容
加入维修社区 - 创建账户
The Super Nintendo Entertainment System (SNES), or simply the Super Nintendo, is a 16bit gaming console released by Nintendo in 1990. The Super Nintendo was one of the best sellers of its time and still has a large fanbase today.
Console doesn't turn on. The power light flashes for a brief second.
I bought an untested SNES, and after plugging it in, no light would come on. I took it apart to see if there was any obvious damage, but nothing aside from a little corrosion around the power input solder points which I cleaned off. Now, after that, the light will flash on for a moment when I hit the switch, but will immediately turn off.
I’m fairly ignorant towards electronics, (i know how to test for continuity using a multimeter and solder/desolder, but that’s about it) so feel free to over-explain if necessary.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
So it appears to have been the shielding not being correctly placed, which was not allowing a proper current ( apparently the shielding has a connection to ground in its design, so not having it on was not allowing it to ground correctly).
这个答案有帮助吗?
得分 0
2条评论:
I’m experiencing the same thing I plug it in turn it on and it blinks red for a second and doesn’t stay on?? I just bought a new cheap av plug for it. Do you think that could be it? It’s not the original av plug so idk if it’s the system or that plug. Help please?
完成的
Same problem exactly. Haven't used in 30 years, I'm thinking it might be the cheap new AV plug.
完成的
添加一条评论
添加你的答案
Daniel Thomsen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 24
总计 775
