Why won't my phone recognize my sim card?
When I turn on the phone it asks for the sim card, but I've already inserted it. I tried using a different sim card and my phone didn't read the other one either. What else can I try?
Sometimes the pins in the phone (little gold prongs) get a little dirty. Try opening the phone to see the sim contacts and check for dirt/flattened/broken pins etc. If they are too flat you can try lifting them up (gently as they are fragile) with a small toothpick/tool. Then, you can try cleaning them with an electronics cleaner (something high in alcohol content so won't leave residue). Let us know if this helps
这个答案有帮助吗?
Thank You all very much. Your advice did in minutes what the carrier including, 7 customer service techs, 2 tech support supervisors,some having heavy accents that i had to keep saying "what" because of my lack of understanding their words. Calls transferred all around the world,including 3-4 dropped calls from South America, Timbucktoo, and i would sware at least 2 calls to Jurrasic Park! Each time repeating the whole situation till I got a sore throat. Let's not forget several family and friends giving their unrequested advice. Really just smarty know it alls, beating their chest saying they wouldn't put up with this c%%%p,never happen to them. Haha right! So thank you all for the very simple advice with remarkable, and quick results. Thank You, Angela Blake
thank you i will try it ,the phone is charging
What if the 2 of the gold prongs were pulled out?
What shall l do then?
Wow that was so helpful! I had the same problem and i was skeptical if just cleaning the sim would do the trick, but boy was i wrong.
Thank you so much one of my prongs were lower than the rest. I used a business card to gently lift it up. This gave the best pressure without harming the delicate piece. Bless you I finally can have a stable number for job apps again!
This can happen for many reasons and there are a few things you can try:
1)Go to settings>general> reset > reset network settings.
2) Use compressed air to clean out the SIM port.
3)Try another SIM card.
4) Open up your phone and lift the gold prongs so there is better contact.
5)Clean the gold prongs with rubbing alcohol.
6) Contact your phone carrier, it might be something on their end.
This might be also useful: http://vkrepair.com/iphone-6-2/iphone-6-...
这个答案有帮助吗?
We're trying to get this sims card to work in a different phone and can't retieve my phone numbers or pictures,etc. What do we do now?
sure you can open the phone but the only easy access is to the battery. In the Samsung Galaxy s5 the mini sd card for additional storage is on top of the slot for the phone sim. It's covered by a flat metal sheet, and the pins can be seen, but not clearly enough to tell anything or even to correct them. There are no instructions for removing this cover. Web searches are all about opening the back of the phone cover.
I have a Samsung Galaxy S20. No way to access battery (been like this since the S8 I think...
Same thing happened with me. I had just cleaned the area where the sim is inserted and then i inserted the sim again and it got detected.
这个答案有帮助吗?
Thank You all very much. Your advice did in minutes what the carrier including, 7 customer service techs, 2-3 customer service supervisors,a few tech support people, also 1-2 tech support supervisors,some having such nice but heavy accents I found myself repeatedly asking "what did you say". Day after day my calls were directed then redirected,to India,Mexico,South America, heck Timbucktoo, and I sware at least 2 calls made it to Jurrasic Park World! Let's not forget several family/friends giving their unrequested advice. Just male smarty know it alls, beating their chest declairing they wouldn't put up with this c%%%p,never happen to them. Haha right.I see Karma stirring the bushes now! So thank you all for the very simple and very correct answer.
Thank You, Angie
Thank you soo much, worked on mine to☺️. It feels good to fix your own problem
Non of mi products which is good all of them a fork
Actually this happens to me a lot. If you take out the sim card, wipe it with a little rubbing alc and let it dry. Then put it back in, it should work!
这个答案有帮助吗?
Thank You, Angie
My phone Xperia m2 coming up no sim no service even tho had no problem over a year
My xperia doing the same but starting to think it's my sim!
There are three possibilities available.
1.Check your sim whether it's properly inserted or not
2.There may be a problem in your sim card so try another one.
3.Your mobile locked to particular network provider.
If your problem persists,Your mobile phone restricted by some network so try to unlock your mobile phone.You can unlock your mobile phone using network unlock code.It's the best way to unlock your phone.If you need an unlock code for your phone visit http://www.onlinegsmunlock.com/supported... I hope it will be very useful to you.
这个答案有帮助吗?
Thank You, Angie
try checking ur springs
这个答案有帮助吗?
Thank You, Angie
my husband had this problem with his phone, it turned out to be because he had pushed the card in too far. He thought it was one of those ones with a return spring like a memory card. lol i pulled it out flush with the lip of the battery line, and it worked just fine. :D
这个答案有帮助吗?
I took my new I phone 5 c and traded with a friend for his Samsung galaxy mega. I took the sim card from the I phone and put in the mega but now the mega wont detect the sim card?
这个答案有帮助吗?
AT&T give the code
but I try enter the code 3 times badly after that the phone did not give me any case to enter any code anymore an the icon that show the sim is gone
I was trying to unlock my phone with the code that AT&T gave me
but I try 3 times and after that the phone got lock no more case to enter any code
no Icon to show the Sim signal in the screen
but I still can play in the application with the wi-fi eternet
my phone is an alcatel 3G evolve
这个答案有帮助吗?
My Nokia 5 just stopped detecting the sim card while busy updating
hi i cant use others sim card into my tablet. when i starting use tm choose your number. i can't insert other sims. please help me
这个答案有帮助吗?
I have the same problem with the sim card on tmobile with my galaxy note 4. The phone will tell me it can't detect the sim card and restart the phone, I'll have to do it two times to get it to see the card, probably getting a new sim card from your carrier will fix it, it's free if you're on the jump on the tmobile, I accidentally locked myself out of my sim card once by entering the pin wrong 3 times, they replaced it free.
这个答案有帮助吗?
Hi okay.. so I got this problem I have new Huawei G630 mobile phone so it won't register the sim card and i don't have internet tho, mobile data and everything that goes with the sim card i tried to put the sim card on other mobile and she worked so the problem is with the mobile but I dont know what is that..anybody?
这个答案有帮助吗?
I got a ALCATEL ONRTOUCH THERE 2 PRONG BROKE OFF CAN I BY PASS THAT OR CAN IT BE FIXED
这个答案有帮助吗?
According to other threads I've found the LG G3 particularly experiences this very issue which seems to be a manufacturing problem with the "seating" of the SIM card, but I have to say I'm about at my wits end with THIS PHONE!! I've already replaced the micro doc (charging port) on my dime (and NO, I'm not one to be rough on my phones and yank out the cord) and forgo the warranted NOT thinking clearly but wanting it fixed out of desperation, I sent it out thru Office Max, NOW THIS just started!! What gives??!
这个答案有帮助吗?
this is an old thread but i had googled my problem tonight when my wife's phone was giving her "sim card not found" error and boy was she freaking out
She explained that she had taken out her SD card, and somehow in doing so snagged the sim card with it, because they are right on top of each other, and both fell out, and when she put the sim back in, it gave her that error.
Perplexed, i watched a youtube video, read some forums, then i got to looking at her phone at the slot and noticed there's 4 little springs, and the 3rd one over wasnt quite propped up like the others, so she took a teeny tiny needle thing, and moved it up, we slid her sim back in, restarted the phone and lo and behold we were back in business! yay go me
So sometimes the simplest things....
这个答案有帮助吗?
I had mobile of Nokia 520 windows, dual sim slot. recently i have problem that one of my airtel sim doest not working in this phone both the slot. but both the slot is working if i am insert the another sim. i could not find any solution. kindly advise if any one would come across such problem.
i can use the same sim in another phone its working, only this phone its not working.
这个答案有帮助吗?
I have the same problem my Ufone sim is not working in my QMobile phone only otherwise its working in all other cellphones
I can't get my Verizon Sims prepaid to get service to even make a phone all what do I do
这个答案有帮助吗?
Type in *22890 call , this should update your roaming and call capabilities.
My SIM at times would not be available. Tried cleaning it several times and checking the pins etc. Yesterday I could not get it recognised. I then wondered if the SIM was actually going in too far - it was. I lined (LG G3) the trailing edge level with the end of the slot - and lo and behold---joy joy!
这个答案有帮助吗?
My phone didn't dectect my Ufone sim but it it detecting all other sims but not mine I had applied all the solutions but its not working... What should I do , its been a week the problem is same.
这个答案有帮助吗?
My Nokia 5 phone has just stopped reading the sim card while I was updating.
For me the solution was to make my phone only use 3g, not 4g. Lucked into this solution, phone was crashing repeatedly if the SIM was inserted.
Go to the secret android network screen by dialing: *#*#4636#*#*
Then set the network connection to be wcdma only for 3g.
Hope this helps someone who had my problem.
这个答案有帮助吗?
I've been plagued by someone thinking they know more than any phone company personnel, etc and I have a Moto e5 cruise never had bit of problem till this person on other side of my bedroom wall decided to get into my phone (there is no such thing as hacking) Motorola tells me that people can delete every email you have ever had and this will disable your phone making it useless, or then they can put in their own info which in my case they did, charging up thousands but I was just a little guicker than they were and unfortunately for us as consumers it becomes a criminal activity and you have no control over an account that you can't use but have to pay on monthly or have it go against your credit while obtaining subpeona to get names, address etc of people that have charged up fortune on your account. Plz Beware
Moto one 5g I have verizon and they refuse to acknowledge my phone and account is hacked
Any suggestions
Im using an IPhone 12 Pro Max, I’m certain it’s the gold prongs that need adjusting, but does anyone know how to open an iPhone 12? Badly need help please!
这个答案有帮助吗?
use the pin that came with the phone and find a small hole on the sides of your phone and insert the pin slightly harshly.
过去 24 小时: 66
过去 7 天: 367
过去 30 天: 1,639
总计 794,005
57条评论
you've paid your bill, checked with carrier that there is no problem?
由 pollytintop 完成的
I have the same problem but none of that worked to help i replaced my battery and then that happend i think its something inside the phone anyone know what to do?
由 alexhendricks63 完成的
My phone wont let me regtister my sim card need help?
由 Chantelle 完成的
someone say's it's because the phone was turned off by the carrier
由 jess 完成的
Sim card won't work in blu studio 7.0ll
由 Crystal Horton 完成的
显示更多的52条评论
