跳转到主内容
The Envy 15 is a line of 15-inch notebook laptops built by HP. The original model was released in October 2009 with updated versions following each year.
80 个问题 查看全部
HP Envy X360 15-bq051sa touch screen
Hi all
Dose anyone know if you can just replace the touch screen on a HP Envy X360 15-bq051sa laptop .
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @burnsclan ,
Looking at the display assembly sub components parts diagram on p.23 of the maintenance and service guide for the laptop, taken from this webpage it appears that the digitizer and the LCD panel are one complete module and not two separate components that can be individually replaced.
On p.23 are the spare part numbers for the various parts. If you search online using only the part number for a particular part, you will get results for suppliers of the part.
If the touchscreen is physically OK there is a touchscreen control board though that may be worth looking at if the touchscreen isn’t working.
Also this link may also be of some help if the touchscreen is physically OK but just not working. See the Update 30/09/2016 to the Chosen Solution How to reinstall touch screen driver? My touch screen stopped working..
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
colin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 71
