跳转到主内容
发布于2018年9月21日,型号为A1921,A2101,A2102,A2104。支持GSM,CDMA / eSIM或 nano-SIM / 拥有64,256或512GB容量可选 / 有银色、金色、深空灰可选。(读作iPhone 10XS Max)
375 个问题 查看全部
Why won't Face ID work?
I replaced the screen on my iPhone XS Max. Everything went back together and worked perfectly. Until… about 4 days later the iPhone shut off unexpectedly and when I turned it back on I was given the notification that “Face ID is not available”. I have read that if Face ID sensor cable was damaged it would cause Face ID to become unavailable. If this is the case, why did it work for a few days and suddenly stop? Someone please help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
It also is possible that face id just stop working even when the phone have never been dropped or came in contact with water or moister. Sometimes things just quit working because of poor quality, age or without a reason (like wear and tear). Just like a tv that stop working afther a few years. And if you want True Tone to work on afthermarket screen you have to program/copy serial no of the original screen to the afthermarket screen, it is not needed for a working Face ID.
这个答案有帮助吗?
得分 1
添加一条评论
Did you reprogram the screen?
这个答案有帮助吗?
得分 0
3条评论:
No I didn't reprogram the screen. Should I have?
完成的
It’s rare but I’ve had cases where Face ID stops working if I don’t reprogram the screen, reprogramming the screen has no correlation to Face ID but I’ve noticed Face ID stops working sometimes when you replace the screen without reprogramming.
完成的
@ifixphoneslol, i didn't know that, i have a Iphone X and when i try to set up face id it shows higher/lower, would it help when i copy the serial no of the originaal screen to this screen?
完成的
添加一条评论
添加你的答案
JDS 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 68
