跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
Will iPhone remain "water resistant" after gasket replacement?
My taptic engine went out in my 7 plus so I replaced it and replaced the gasket as well. Should I trust the water resistance on the new gasket? I’ve read that replacing the screen affects water resistance because of gaps between the earpiece and the screen but in my repair, the only thing replaced was the gasket and the taptic engine. Can I still trust the water resistance just like when I bought the phone?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Typically the liquid resistance shouldn’t be trusted after about a month from brand new. But to answer your question, I wouldn’t trust it. Removing the screen whether it was cracked or not will break the adhesive seal. Without the proper tools and equipment that only apple has, you won’t be able to seal it properly. I myself replace it in my shop but I inform my customers that although I replace the seal, just like Apple, that I do not guarantee it will hold up.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
jimmysofat6864 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 266
