跳转到主内容
加入维修社区 - 创建账户
The 1999 Chevrolet Malibu is part of the fifth generation (1997-2003) manufactured by General Motors. This is the first smaller, front-wheel-drive Malibu that General Motors put back on the market after the Malibu line was temporarily discontinued in the early 1980's.
2008 Chevy Impala LT 3.5L engine, RPMs randomly cut, car won't go 40+
My boyfriend's car sometimes randomly acts up! The car will jitter and then has a hard time getting up to 40/45, and will not go past 45. The car runs fine when it gets up to speed, but in order for him to be able to drive the car when this occurs, he must manually put the car into 2nd gear. After shutting off the car for a few minuets and restarting the engine seems to fix the issue, however shutting off the car and turning it on doesn't always fix the problem.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
First check the fuel pressure with a gauge. There is a test fitting on the fuel rail and you can get the fuel pressure specifications on the internet. If the pressure is good check for an bad spark plug, wire or coil. Pull a spark plug wire one at a time and see if it makes it worse or stays the same. If it stays the same pull the spark plug out and see if it looks ok if it does swap the plug with the next cylinder and pull a wire and see if the miss is on the original cylinder or if it switched to the other cylinder. If it's in the original cylinder change the plug wire with a different cylinder and pull each wire one at a time. If the miss stays in the original cylinder it is most likely an ignition coil. If it has multiple ignition coils switch it with another coil and see if the miss moves to another cylinder. If it moves you need a new coil. If not check the cylinder for compression, if the compression is good it has a fuel injector. If you are not mechanical inclined I would take it to a shop for a diagnostic. It could also have a problem with a computer sensor and may have a check engine light on and it could let you know which cylinder is misfiring.
这个答案有帮助吗?
得分 1
2条评论:
We found out that his car hasn't had a tune up in a while, right now we are thinking it is spark plugs. According to the sprint drive, the car keeps having a cylinder 1 misfire; and occasionally it tells us to check the battery. The battery was replaced not too long ago. Thank you for your advice!
完成的
crankshaft sensor is going south
完成的
添加一条评论
添加你的答案
Cam 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 20
总计 1,301
