跳转到主内容
Apple的9月20日发布的Apple主流2019 iPhone带有6.1英寸LCD触摸屏,双摄像头和六种可用颜色。iPhoneXR的后继产品。
474 个问题 查看全部
iPhone 11 turning off after screen replacement
I repaired an iPhone 11 it was a screen replacement and back glass replacement with the forward laser machine everything seemed to work fine but when the phone is on for a couple minutes the phone turns off and back on. After it randomly restarts it acts like normal until a couple minutes have passed it does it again. I’ve tried a different battery and even the original screen but it still does this. I’ve also disconnected the front speaker flex in case it was causing problems but it still does it. I put it into dfu mode and updated it successfully now its on a white screen that says attempting data recovery but it keeps turning off before it finishes any ideas on how to fix this power off problem.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
have you try updating the phone
完成的
添加一条评论
3个答案
已选择的解决方案
In this case, the charging flex or the microphone/flashlight flex next to the camera might be damaged.
These contain sensors (prs0 and mic2) that cause the phone to restart after some time if no valid signal is received.
这个答案有帮助吗?
得分 0
添加一条评论
I had the same problem with a iPhone 11
tried everything
last resort is changing out the battery
这个答案有帮助吗?
得分 0
添加一条评论
If the screen was replaced without disconnecting the battery it will short circuit your phone therefore once that is done even a new battery will not fix it it's happen to me twice once when I paid for it to be fixed and second time I did it was trying to move to fast
这个答案有帮助吗?
得分 0
2条评论:
Any fox for this ??
完成的
Oh $@$* this happened to me. Does the iPhone eventually go out? I’m trying to transfer my data before i send it back to asurion?
完成的
添加一条评论
添加你的答案
Daniel 将永远感激不已
浏览统计数据:
过去 24 小时: 10
过去 7 天: 74
过去 30 天: 276
总计 8,363
