I also noticed that this problem also affects incoming calls. The moment I answer the call, the screen goes off and after pressing the home button, the image appears on the display, but as if it was blocked and I can't press anything as if the touch was not working. This only happens when you make a call. Besides touch, the screen works normally. Is that a lcd display problem?
由 ManiaQ 完成的
