跳转到主内容
发布于2011年7月21日。Core i5或Core i7处理器。雷电(Thunderbolt)接口。本机也用于Mac mini Server配置。
204 个问题 查看全部
Make silent extra cooling for noisy Mini server?
I have got a 2011 Mini Server with i7 quad core with two discs and I am using it for EyeTV in my living room. Problem is that it gets really noisy when compressing recording (even with Elgato H.264 HD attached) and it get even worse if I have got Plex server running as well.
Question is: Has anybody made some additional cooling for this nice machines? I have thought of some kind of cooling stand with a big silent fan. The stand could be attached so it replaces the bottom cover and just forces extra air in through the Mini.
Any ideas?
Kind regard, Karsten Hartmann
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
Take a look at this, the heat sink is on the bottom of the Mini: http://eshop.macsales.com/item/Newer%20T...
这个答案有帮助吗?
得分 3
1条评论:
The position of the stand is right, but the base should contain a big silent fan to increase the airflow. This one looks as an absolutely passive stand just for lifting the unit.
完成的
添加一条评论
while this doesn't answer your question specifically, the cooling strategies may point you in the right direction.
Should I replace the thermal paste on my mini?
Cheers
这个答案有帮助吗?
得分 0
添加一条评论
Mine peeked at 107c. So, for my mini, i bought an extra cover ($15). Drilled 1/8 holes evenly spaced around the edge of the cover of the slanted brim that faces forward. On the un-sealed side only. Machine stays below 99c while hd encoding. Top is barely warm now. Drastically increased air-flow from exhaust port! Just clean out the mini periodically. And make sure u have new thermal paste. Fan is also quieter at full speed.
2012 2.6 quadcore i7.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Karsten Hartmann 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 8,668
