跳转到主内容
Google公司发布的二代Pixel XL版本,发布于2017年10月19日。配备6英寸圆角P-OLED显示屏。纯黑和黑白两种颜色及64GB或128GB存储空间可选。
70 个问题 查看全部
screen won't turn on after battery replacement
did a battery replacement using your kit. screen wont turn on. if i hold in the power button for 30 seconds it will vibrate. i’ve rechecked all the connections. can’t find anything via google. i was pretty careful. not sure what i could have messed up.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
There’s a very good chance you damaged the screen in the removal process. I have yet to replace a Pixel 2 battery, but since it’s the same procedure between the Pixel 1 and 2, you almost always damage the screen. I’ve done 2 first gen Pixels since I’ve opened my shop and both times I had to replace the screen. And given the 2 uses an OLED panel, it makes it more likely for the average person or even a skilled tech to damage it. A quick way to test it is to power the phone on and wait a few minutes for it to boot. Although the OLED panel is damaged, the phone should still boot. If you plug it in to the charger and it chimes or vibrates, or if you call it and it rings or vibrates, then we can conclude the phone boots up and the display is damaged.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Nathaniel Gallagher 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 30
总计 937
