跳转到主内容
苹果第四代智能手表,含可选的蜂窝连接支持,2018年9月21日发布。
124 个问题 查看全部
How to remove the digitizer (no glass) from OLED panel?
I tried to do a glass-only repair and remove the OLED+digitizer+polarizer from the (cracked) glass instead of removing the digitizer+polarizer+glass from the OLED panel. It didn’t go well… I have a polarizer (I think) that’s flaking off and a small bubble imperfection on the edge of the digitizer. The display and touch both work, but I can’t reassemble it this way. Photos attached.
How do I remove the digitizer from the OLED panel without ruining the OLED? I tried heat once and it burned the OLED, presumably since there was no glass to act as a heat sink. What’s the best way to do this? I really don’t want to ruin the panel… they’re so expensive. Thanks in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
I ended up *very carefully* separating the digitizer from the OLED panel by using a 0.05mm molybdenum wire. Lots of glue rolling ensued. Now I have a fully functional bare LCD/OLED panel. Ordered a new glass with digitizer and then I’ll be set.
One YouTube example used a hot decal scraper and that was just too scary for something so small. No thanks.
这个答案有帮助吗?
得分 0
添加一条评论
Sadly I have not found anyone with the needed skills or tools to replace the watch crystal reusing the panel without having visible defects. In the end I just replaced the full assembly.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
J.R. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 308
