Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units.
Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
What is the make and model number of the refrigerator?
What is the actual temperature in the bottom part of the fridge? Use an appropriate thermometer and check the temp reading.
Most refrigerators are set to approx. 0 deg. F (-18 deg. C) in the freezer compartment and approx. 37- 40 deg F (3-5 deg. C) in the refrigerator compartment
Hi,
由 jayeff 完成的
