跳转到主内容
Repair and disassembly information for AirPods Max wireless noise-cancelling headphones.
Is AirPods Max battery user replaceable?
Can a common user replace Airpods Max battery ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 12
添加一条评论
4个答案
已选择的解决方案
Officially, its not user serviceable, at least this is what Apple will tell you.
But as the teardown shows, once you get below the only point where they used adhesive, you can quite easily replace them. Or could - since you would have to find a replacement part first. But the batteries are not glued down and they do have a real connector! These AirPods Max did get 6 out of 10 Points for being somewhat repair friendly - contrary the the other members of the AirPods family, who earned a whopping… 0 points !
这个答案有帮助吗?
得分 7
添加一条评论
Unknown at the moment, check back to the teardown for an answer later.
这个答案有帮助吗?
得分 0
1条评论:
Ooh, would be nice if a bigger capacity battery was made for the AirPods Max. I think I’m only getting ~6 hours with noise canceling on and the volume at “4 from the highest”. And my commute is ~45 mins each way.
完成的
添加一条评论
Yes it is! Just need to get batteries that work.
这个答案有帮助吗?
得分 0
添加一条评论
They’ve just launched - wait for the teardown.
Although it’s most likely going to be a no.
这个答案有帮助吗?
得分 -1
1条评论:
seeing has how the cups can be moved, and only adhesive holds the plastic covers down, I don’t think it would be *that* difficult compared to some other Apple products.
完成的
添加一条评论
添加你的答案
Babu s 将永远感激不已
浏览统计数据:
过去 24 小时: 16
过去 7 天: 67
过去 30 天: 269
总计 10,462
