跳转到主内容
发布于2018年9月21日,型号為 A1920、A2097、A2098、A2099、A2100。相容的行動網路為2G、3G、3G+、4G(LTE)、4G+(LTE Advanced)。A2100僅有nano-SIM,其餘版本為nano-SIM與eSIM。儲存容量有64 GB/25B GB/512GB三種。顏色有銀色/太空灰(深空灰)/金色三種。(機器讀作iPhone 10s)
398 个问题 查看全部
Cracked screen HELP?
Hi there,
basically.. in short, i have an iphone xs, the screen is cracked however still fully operational, jus a crack in the screen. i a a mechanic so good with hands however phones aren’t my forte, what kit do i need in order to replace the front screen please ( including tooling as ill need to do the same to an iphone x and a apple watch… its been a hard year ,,
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
You can buy kits here on ifixit. You’ll need to a a complete screen replacement as they use OLED panels and it’s really difficult even for experienced techs. They’ll include tooling and you can find guides on here as well. Just avoid using an LCD and stick with OLED. LCD runs the risk of damaging the connectors due to increased current consumption and can impact battery life.
这个答案有帮助吗?
得分 0
添加一条评论
I refurbish screens but it isn’t worth buying all the equipment if you’re only going to refurbish one screen as it costs thousands. There are other methods that you can use but they are DIY methods. For example to remove the glass you can use a heat gun and plastic to get under the glass and take it off. Then when installing the new glass, you’d use LOCA instead of OCA, then use an ultra violet light to cure the LOCA glue.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Paul Rumary 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 34
