跳转到主内容
加入维修社区 - 创建账户
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
Home button doesn't work
Ok. So I need some help. When I opened my phone the other day, I replaced my battery but before that I accidentally cracked a lil part of the screen below the home button as pictured below. Then I really screwed up. I accidentally dropped the phone and the front camera cable snapped in half. I learned a valuable lesson lol. Then I put it all back together and the home button/id isn't working. Tried replacing it with 2 other buttons and no click for the home button on either one of them.``
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Solution. I replaced the digitizer and it's working again. For some reason the digitizer and home button functionality are tied into each other.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
hello Andrew,
click and touch id will only be available with your original button. It cannot be replaced due to security restrictions. You probably damaged one of the tapes (the shorter one) of the screen. The most common cause of such failures is the tearing of the tape when trying to remove the sticky screen. The damage does not have to be large, there are 16 connections with a cross section of less than 0.5mm inside. Screen replacement will help - this is the fastest and cheapest solution. You can replace the backlight assembly itself, cost around $ 8-12 but it will be difficult to get it right the first time. Additionally, you will need a good soldering iron and a lot of manual skills. Good luck.
这个答案有帮助吗?
得分 1
2条评论:
So will replacing the digitizer help the home button to work again?
完成的
Not digitizer. New display set. Take it to a repair shop, have them confirm the diagnosis (to be sure, have to see it)
完成的
添加一条评论
添加你的答案
Andrew 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 135
