跳转到主内容
Apple的 MacBook Pro 的產品線是專為可望極致效能專業使用者所打造。MacBook Pro 产品线包括了MacBook Pro 13" (一體成型機身款), MacBook Pro 15", MacBook Pro 15"(一體成型機款), MacBook Pro 17" 和 MacBook Pro 17" (一體成型機款)。
19983 个问题 查看全部
2009 model won't let me use Express card eSATA in Windows
Hey,
I have a Silicon Image SIL 3531 SATA controller, it is a Express card from Kanguru solutions and I used it in my 15" MacBook Pro from 2006 all the time with my 32 GB eSATA flash drive. I upgraded to a 17" MacBook Pro in 2009 and I can ot get this Windows only card to work. It is seen by the system but gives me this error.
This device cannot find enough free resources that it can use. (Code 12)
If you want to use this device, you will need to disable one of the other devices on this system.
I have disabled the Firewire (IEEE1394), bluetooth radio, isight camera and still I am unable to get this to work. Any suggestions would be greatly appricated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
最有帮助的答案
I agree that there is no way to make your card work. I'm not sure what you're using it for, but perhaps purchasing a new SD card to go with your new MBPs built-in SD card slot would provide a good enough solution?
这个答案有帮助吗?
得分 1
1条评论:
OK everyone thanks for the help. There is no SD on the early 2009 17" MacBook Pro. It is an ExpressCard (sorry called it PCIe which is what ExpressCard is) and I now believe that the EFI firmware is not assigning resources to this card. Shame, I used it to power this http://shop.kanguru.com/index.php/flash-... and without the powered eSATA card they are only good as USB for this system.
完成的
添加一条评论
Does the card go in the computer's expansion slot?
if so, check the driver for the controller and make sure you have the current version, does it work in mac os x, what version of windows are you using? try checking the driver and checking the connection on the card.
这个答案有帮助吗?
得分 0
添加一条评论
The MacBook 2009 was redesigned and the Express Card will no longer work.
The MacBook 2006 has a PCIe slot 34 which was a 32 bit card. The slot was equilivent to a PCMCIA slot used in older model G3 laptops. The short answer it will not work. The newer processors are 64 bit and older cards will not be supported.
这个答案有帮助吗?
得分 0
添加一条评论
Hi, both PC have a PCIe slot so I do not think the PCIe slot is the issue, but you might be right about the 64 bit, however kanguru systems says the controller on the card and driver support 64 bit. I will check with Kanguru about this.
这个答案有帮助吗?
得分 -1
1条评论:
You should update your question with this information, rather than posting it as an 'Answer'.
完成的
添加一条评论
添加你的答案
ibweaponx 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,464
