跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
Flashlight and magnifier app don’t work.
I replaced my rear facing camera, which solved the blurring and focusing problems, but now my Flashlight, Magnifier and Portrait mode do not work. Thank you!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The flashlight will typically disable itself if the phone detects a fault, are both cameras definitley working?
这个答案有帮助吗?
得分 0
2条评论:
I’m not completely sure. The camera works better in my IPhone 7 Plus,but Portrait does not work, nor does 1x. I can only take photos on 2x. I appreciate your thoughts, as I don’t know much about this subject. Is it possible that the replacement camera I received was defective or is this a different issue all together?
1x - does not work
Magnifier- does not work
Portrait- does not work
Flashlight does not work
完成的
yeah, if the 1x isn't working that will cause the others to stop as:
Magnifier uses both cameras
Portrait uses both cameras
Flashlight will disable itself if it detects a fault
New camera should work otherwise you may have a logic board issue
完成的
添加一条评论
添加你的答案
Jessica Dettinger 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 115
