跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
How to tell what's broken on a phone that's not booting
Today I got a battery and a screen replacement for my iPhone SE 1st gen and followed instructions to replace both.
At the end of the procedure, before pushing the display back in I booted and everything was working fine, the new battery was at 30% and the screen, camera, proximity sensor were all working.
I then shut the phone down and pushed the screen in, but it didn’t fit, it was slightly too big and one corner of the frame had a slight dent. so I used my sucker to pull the screen back out in order to fix the dent in the frame, but I pulled too hard and instead of pulling down close to the home screen I pulled at the top, this moment I think I managed to damage something, because when I fixed the dent and put the screen back in (with a lot of applied pressure, this is the other moment that I suspect I might have broken something) the phone didn’t boot anymore.
I hope I only broke the wire from the screen, but the phone gives absolutely no response when I plug it in or when I try to boot it.
Is there a sure way to tell what’s broken? if it’s the motherboard or the screen or whatever?
I still have my old cracked screen which I could try placing back but I first would like to know if it’s really the screen or maybe something else.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Please anyone?
完成的
添加一条评论
1个答案
The best option you have now is to put back your old screen and see if the phone will boot.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jakob 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 80
