跳转到主内容
Apple 在 2019 年 3 月 更新了他们的 iPad Air 平板电脑,配备了 A12 仿生处理器和一块 10.5" 屏幕。
39 个问题 查看全部
Does the iPad Pro 10.5” lcd work on the iPad Air 3rd gen?
Hi all,
as the title says, does the iPad Pro 10.5” lcd work on the iPad Air 3rd gen?
I have an iPad Air 3rd gen in for repair which the customer had told me was an iPad Air 1 so don’t have the lcd display for that model in stock but my local supplier has iPad Pro 10.5” screens in stock and are cheaper than the iPad Air lcds.
I have a separate iPad Pro 10.5” digitiser which when connected to the iPad Air 3 works fine but don’t have the lcd to test.
thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
iPad air 3rd gen and iPad pro 10.5 screens are identical there are no differences between the two display panels. The iPad air 3rd gen is locked at 60hz by software not hardware so yes an iPad air 3rd gen display would work fine on an iPad Pro 10.5 and vice versa. Also if you plug in an iPad Air 3rd gen display on an iPad Pro 10.5 the refresh rate of 120hz is available as both iPads have 120hz display panels. Like I said the Air 3rd gen is software locked at 60hz.
这个答案有帮助吗?
得分 1
添加一条评论
Although they may look the same and even have the same connectors, I don’t believe they are compatible. Most if not all Pro models have a higher refresh rate so that may cause compatibility issues.
For the future, I would confirm the customer has the correct model by asking for the A number. If I have to special order parts for anything, I take full payment up front and contact the customer when they come in.
这个答案有帮助吗?
得分 0
添加一条评论
I’m no expert, but it sounds like it wouldn’t work because apple’s screens in general are usually programmed to the specific model. Even if they had the same connectors, it probably wouldn’t work. Plus, an iPad pro’s display supports 120hz while the iPad Air is locked at 60hz
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mwr_allen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 52
总计 1,689
