跳转到主内容
Repair information for the Samsung Gear Icon X SM-R150 wireless earbuds.
3 个问题 查看全部
Left Driver got broken when I was cleaning the ear tips
I was cleaning out the ear tips of my icon x and then the toothpick that i was using punched a hole in the driver. I would like to be able to tear these down and replace the driver, but if that isn’t possible, thats ok.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Did you punch the driver itself or the protective mesh? There is a big difference. In case you pushed the mesh in the tip of the buds, I would recommend leave it as is. If you pushed the driver I would recommend the same. You are working with tiny, expensive and fragile components. In first place the earbuds are not meant to be resealed so you will never get them to be as they are now. The actual replacement of the driver itself is also a very hard task. If you can come across cheap old broken or used once, it might be a fun learning experience to interchange the component but don’t expect them to come out as they used to be or even working at all.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Joseph Taufen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 188
