跳转到主内容
7.9 inch display / Model A1454 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
28 个问题 查看全部
iPad internal hardware removal
Hello, my friend had this iPad from afew years ago. She really wants all her photos off the iPad but when she was younger she thought it would be funny to burry it because the screen broke. It’s been underground for 4 years and we are wondering if it is possible to remove the internal hard drive and put it into a new iPad.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
@kmab “remove the internal hard drive and put it into a new iPad “ can’t be done. there is no internal hard drive etc. All the information, files etc., are stored on IC’s (Chips) that are soldered to the logic board. There is no way to recover any of this. Consider this a total loss, sorry.
Update (11/27/2020)
@kmab you know just for completion sake, post some good pictures of the iPads logic board with your QUESTION. Let’s see what we are dealing with here. There may not be any corrosion etc. on it and maybe it stayed well preserved while buried in the ground. Now, don’t go ahead and just rip it apart, use the same care as you would if it was new. Use these guides iPad Mini GSM Repair to work on it.
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 1
添加一条评论
@kmab - There is one way to get your photos!
It won’t be cheap, but if you really need to get them this is your only option!
You’ll need to ship your iPad to someone who has the deep skills to fix it so the photo’s and another info can be salvaged.
As an example: Jessa Bethany should be able to help you.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kai 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 70
