跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
922 个问题 查看全部
Glass popping out from plastic border
I noticed that my phone’s glass was slightly popping out towards the top from the plastic surround, and when you push it in, it discolours the top of the screen (as if you were pushing hard on the touchscreen itself). Fast forward a month and the glass is popping out so badly you can see the actual backlight shining through the gap. The screen itself still works fine.
I have never dropped the phone except for one time where I tripped on its charging cable. Even so, the screen was still flat. I opened the phone before, only to find out my battery was perfectly fine. It was made in February this year, after all.
What is happening here? I don’t want to spend my money on a whole new screen only for it to still be something else.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个回答
已选择的解决方案
Sometimes frame bezel gets stuck because a screw is loose or there is a bend in the metal bracket- if you are comfortable opening it again just look at the edges around the screen and check to see if all screws are accounted for- if not you may have one loose inside the phone.
这个答案有帮助吗?
得分 1
评论:
Not sure if I should've accepted this but I did find a loose screw that caused the camera and proximity sensor to move slightly. The battery was actually bulging aswell after I took it apart again.
完成的
添加一条评论
If still under warranty (and all is original) you can make a visit to the Apple Store, there is a chance that they will put a new screen in it under warranty .
这个答案有帮助吗?
得分 0
评论:
There are no Apple Stores in my area - which is probably a good thing.
完成的
添加一条评论
添加你的答案
amatsuda 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 27
