跳转到主内容
The Acer Chromebook 15 cb3-532-c47c is a Chromebook computer sold by Acer.
3 个问题 查看全部
How do I delete. " this setting is managed by your administrator"?
I am the owner. I am trying to connect my acer chromebook to my android phone and it won't let me. It says this setting is managed by your administrator. How do i fix it and delete it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 9
添加一条评论
2个答案
已选择的解决方案
Google provides instructions for connecting your Android phone to your Chromebook. Note that you have to be logged into the same Google account on both devices. See the page titled "Connect your Android phone to your Chromebook - Chromebook Help".
If you're being restricted by an Administrative policy, you'll need to remove the Chromebook from the managed network. Outside of contacting the network administrator, the only other way to do it is to wipe it completely, assuming the “forced re-enrollment” setting is not enabled (which it is by default). It's also possible that Developer Mode that's used to wipe the computer is blocked by your administrator. See "How to Reset a Managed Chromebook (School, Work, or Enterprise) - Complete Tutorial (2022)" for the complete set of instructions.
这个答案有帮助吗?
得分 5
添加一条评论
Go into Control Panel > User Profiles and make sure you are the administrator. If not, change the account type.
If you don't have Pro version where Group Policy has been set to manage settings, then it could be a bug, possible caused by your antivirus. So I'd first uninstall the Antivirus to try running with built-in Defender which always offers best Windows performance with least issues, and is from Microsoft who knows how to protect their OS best.
This can also be caused by a wrong setting or a few wrong registry values.
See also the fixes here:
https://www.minitool.com/news/some-setti...
https://www.apeswithcomputers.com/articl...
这个答案有帮助吗?
得分 0
1条评论:
You might have understood this person's problem. It's a Chromebook, not a Windows laptop. Currently have the same issue.
完成的
添加一条评论
添加你的答案
melindatottle21 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 25
过去 30 天: 88
总计 6,661
