跳转到主内容
Repair guides and support for your Philips TV.
220 个问题 查看全部
Philips 50pft6550 backlight faulty
Hi,
I turned on the TV and the picture was black but the sound was ok, therefore I did the light test and I could see that the panel is ok.
I have tested the backlight on the power board and I got 75V on Led1 and 75V on Led2, both on stand by and tv on.
I can't find the datasheet of the power board(photo attached)
Is there any way of getting the data sheet?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
@essh19 the voltages from your power board sound about right. Check the backlight strips since they have a tendency of failing. Backlight strips are the same as for a Vizio D50-D1. Part number for the strips should be YX-50024011-4E761-0-B-63M -53285
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Elad s 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 157
