跳转到主内容
Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
114 个问题 查看全部
Replace the Logic Board after power cable is stuck in port?
I'm trying to repair my neighbor's 2001 iBook. The end of the power supply connector has been stuck in the laptop for almost 9 years! I read the iFixit manual on how to take-apart the lower case to access to power supply port. I was able to pry out the connector out of the port with tweezers and electrician's dental picks. I separated the port from the logic board by accident. Do I have to replace the entire logic board or the power supply section of the logic board?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hi! It depends on what you mean by "separated the port from the logic board", but it sounds likely you just need a new DC-in:
[关联产品丢失或禁用: IF150-011-1]
The DC-in is not actually part of the logic board itself, but a removable module. If the port has come off of the "logic board"-like part of the DC-in, then you should just be able to replace the DC-in. If that doesn't look like what you need to repair the machine, let me know.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
dadocta4880 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,088
