针对近期推出的Mac笔记本电脑以及台式机的完全拆卸和组装指南。
34077 个问题 查看全部
iBook G4 has bad airport card. How do I disable airport
I get a kernel panic when iBook boots up. I think it's a bad Airport Card. How can I disable airport in safe mode?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 1
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
3个回答
已选择的解决方案
Open your system preferences, go to Network and turn it off.
这个答案有帮助吗?
按维修分数 1
评论:
Thanks Mayer, but I get the kernel panic on boot up, so the only way for me to access the iBook is in safe mode. Airport is disabled there and grayed out in Network pref's. I know there must be a terminal command to disable it. I'm thinking I can just disable the airport card and buy an wireless USB adaptor...
I am in Tiger
添加一条评论
The Terminal command would be: sudo ifconfig en1 inet down
这个答案有帮助吗?
按维修分数 0
添加一条评论
Out of curiosity, reboot the iBook while holding down SHIFT to get into safe mode.
Does it still kernel panic?
Restart OS X normally. Does it still kernel panic?
If so, have you considered physically removing the Airport card?
iBook G4 12" 1.33 GHz AirPort/Bluetooth Board Replacement
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
KathyD 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 416
