跳转到主内容
Model A1990 / EMC 3359. Released in May 2019 with new 6-core and 8-core processor options.
88 个问题 查看全部
MacBook Pro 2019 can't handle Photoshop? Or am I crooked?
Sorry, my english not the best!
In 2019, I bought myself a poppy after working in the office for 12 macmini.
McMini had NO discrete video, 8 RAM. I3 processor in my opinion. Worked with an external SSD.
In short, in terms of characteristics, it was weaker than my mac now by 2-3 times.
I liked worked on macmini very much, everything quickly, Photoshop did not lag.
Then I quit my job, but I still had to tinker with the Photoshop layout, and then some kind of game began.
On a MacBook, the same source works just awfully. Everything lags and farts. I wore it for repairs - the first time my motherboard was replaced under warranty (as if the voltage was not the same), but even after that everything remained as it was - bad. Then I literally bored 5-6 offices (including the officials), they ran tests / renders and none of them found any problems.
Conclusion: According to the service center, the MacBook is now working properly and working as it should, BUT ....
My Macbook pro characteristics:
MacBook Pro (15-inch, 2019)
2.6 GHz 6-core Intel Core i7 processor
16 GB 2400 MHz DDR4 memory
SSD 256 default makovsky
2 videos (diksretka + integrated)
Radeon Pro 555X 4GB
Intel UHD Graphics 630 1536 MB
It works like this:
https://youtu.be/rvmbBDn1Sk4
Yes, the layout is heavy. Yes, lots of graphics and smart objects. But the paradox is that it works perfectly on weaker machines.
By simply starting the program, the temperature rises sharply to 60-70 degrees. If the computer is turned off for 2 days, then when turned on, the coolers will spin at maximum speed, although the computer is cold.
TurboBoost is not affected by anything, it works normally, by itself and without me.
I work with an external monitor 1920x1080 and nothing more. The video was recorded from him. The influence of retina is excluded.
I already installed clean OS, both new and old, and went through a bunch of versions of fsh (both pirates and paid for a subscription), checked the settings, turned on / off discrete video in fsh - it does not help. Even that mini was reset to zero. + Then I tested the same layout on a PC with characteristics EVEN worse than that of the MacMini - everything is fine.
The bottom line is that I have a computer that, according to its characteristics, is ready to do a lot. But in fact, this is such a flounder ...
What could be the problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Check your system for a virus or other malware.
I would also clean out some of your stuff off your internal drive. systems with small SSD’s get into trouble when they need more virtual RAM, caching or scratch space.
Get your system down to 100GB of free space that should really help!
这个答案有帮助吗?
得分 1
添加一条评论
I would like to point out that photoshop is a more of CPU based application and not a GPU. I used to run photoshop and even premiere on a 13” 2013 retina pro and that only had a dual core i5 and it seemed to do just fine. I would do a search on how to optimize your settings for your machine. Does this happen as soon as you open your project in photoshop or does this happen in other applications as well?
这个答案有帮助吗?
得分 0
1条评论:
This happens in other applications as well:
Premier
Illustrator
Blender
I tried all possible settings both in the system and in programs - nothing helps. The official service center did not even find any problems, but it lags and works worse than the 2012 McMini without a descriptive video card. I described everything in the text, and about the settings too. Please read completely first
完成的
添加一条评论
Did you replace the battery? Power service may be throttling you due to inability to provide peak performance. Likewise, have a peek at your thermal paste on your CPU, it gets old and less effective over time. Lastly, consider adding cooling to your VRMs, those can overheat without your knowing and throttle the CPU voltage https://www.reddit.com/r/macbookpro/comm...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Евгений Голубев 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 14
总计 360
