跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
873 个问题 查看全部
Replacing Battery with Cracked Rear Glass?
I’ve reviewed the process for replacing the iphone 8’s battery. It looks very similar to the 6 and 6S i’ve done before. But there is a catch:
My rear glass is shattered. Can I still replace the battery? Or will trying to remove the battery/battery adhesive end up destroying the glass? Is the battery adhesive what is holding the glass together right now?
The previous phones I’ve opened for battery swaps were all undamaged, or only had front screen damage. I don’t want to take this phone apart and end up with half a phone and a pile of glass shards and dust.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi, you won’t damage the rear glass as the battery has its own adhesive similar to all the previous iPhone models.
Hope this helps, Luke
这个答案有帮助吗?
得分 0
2条评论:
But what I'm saying is, is the battery's adhesive stuck directly to the glass or is there some other kind of intermediate layer between the two?
完成的
The back glass is a separate layer, there is a metal frame between the two.
完成的
添加一条评论
添加你的答案
John M 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 489
