跳转到主内容
The 2014 edition of the Kindle, part of the 7th generation, includes a touchscreen and same form-factor as the Kindle Paperwhite, but lacks the backlight.
28 个问题 查看全部
How can I repair my kindle's screen?
Hello.
so I have an 8th generation Kindle (iFixit only let’s me mark the publication as 7th generation), and the screen stopped working one day in which I bended it a little bit accidentally. The device still works, it’s only the screen what doesn’t display content properly. I adjunt a video showing the problem, please watch it to understand: https://youtu.be/4z5dJMqSwvo
My question is how can I repair it? Maybe changing the screen will be enough?
I want to repair it. I hate throwing away stuff and this waste culture we have.
I have already tried resetting it. The model number is SY69JL.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
4条评论:
Have you tried restarting it?
完成的
yes. it stays the same.
完成的
Hi @greensunn
What is the model number of the tablet?
Kindles can and do vary and to get the correct screen you need to have the exact model number and not go just rely on the model name and/or generation to find a replacement
完成的
@jayeff hey, the model number is SY69JL.
完成的
添加一条评论
1个答案
Hi @greensunn ,
Couldn’t find a screen replacement guide or teardown video for your model but found this video that shows how to replace the battery in your model, which at least will help you to open the tablet so that possibly the screen connections can be checked and the screen can be replaced if necessary. Although it looks like the screen is mounted on the systemboard somehow so this may be very difficult.
Also I couldn’t find a replacement screen online either. Hopefully you may have better luck.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Trol lolol 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 186
