跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
873 个问题 查看全部
iPhone 8 microphone works in videos, however not on calls/voice memos?
Hello,
I have a similar issue to someone else on here, the microphones on my iPhone 8 only appears to work while doing specific things - the microphone works fine with Siri, Front and Rear facing video, but doesn’t work for calls on both speaker and earpiece, pretty sure FaceTime & voice memos records a flat line and plays a cracking sound. I am thinking it is the bottom microphone that isn’t working, and am hoping it is not logic board.
As for history; the screen and back are cracked (bought it like this) particularly near the dock section on the back. However, everything else works fine (as far as I can tell) and I opened the phone up and all water damage indicators are white and the phone is mostly clean with little dust.
I am re-posting this question as I have just received a replacement housing with a new bottom flex charging cable (which has pre-installed microphones), and will install it in the next couple of days. I wanted to see if anyone has any more ideas before I consider spending more money on a new screen?
Thanks in advance, and for the one person who replied before confirming my suspicion that the bottom microphone may be the culprit.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
9/10 its the buttom microphones.
Most likely one or both flex cables leading to the microphones are ripped/torn due to lack of protection on the rear side.
I would test this in the new housing.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
TmG 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 131
