跳转到主内容
A1418 / EMC 2833 / Late 2015 / 3.1 GHz Core i5 or 3.3GHz Core i7 Processor. Released October 13, 2015.
93 个问题 查看全部
Chime but delayed display
Hi guys,
We got an imac in that chimes on power on but it takes 10’s of minutes before we actually see anything on the display.
Sometimes it will attempt to boot from the internal drive (we end up seeing an apple logo and loading bar) but it just restarts.
After trying to go into the boot menu (option key) and not getting anything on the screen, we left it alone for a while and it automatically booted into a catalina based recovery mode. We tried plugging in an external tester and can see it in disk util, but cannot see the internal drive listed there.
When we try to install an OS on our tester, it says we don’t have the firmware to do so so.
Before we open this one up (adhesive based), is this looking like a logic board issue or could a bad internal drive cause this type of behavior?
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Using a USB keyboard what happens when you try to go into Target Disk Mode?
完成的
@danj Hi Dan, same thing. The backlight comes on but nothing on the screen.
完成的
@repairk - If thats the case you got a logic board issue as the display should be showing the Thunderbolt Icon on it!
完成的
添加一条评论
1个答案
已选择的解决方案
So for anyone wondering, this was indeed a drive issue. One of our techs just opened it up and removed the drive. It boots fine now with our tester drives, though we have not tested it extensively, but it’s definitely looking like drive was at fault in this case.
这个答案有帮助吗?
得分 0
1条评论:
This doesn't make sense!
完成的
添加一条评论
添加你的答案
KRepair 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 23
