跳转到主内容
An i7 gaming laptop released in September 2017. Created to fight heat and keep air flowing with thermal engineering systems.
21 个问题 查看全部
Mon ordinateur émet des BIP
Bonjour,
Mon ordinateur portable emet un bip mais ce n’est pas tous le temps (Legion Y520 )
J’ai changé la RAM , Les Disques dur sont OK (verifiés avec un logiciel) , j’ai vidé les condensateur avec la manip qui consiste a rester appuyé sur le bouton demarrage plus de 1 min .
Merci pour votre aide
—————————————————-UK version ———————————————————
Hello,
My laptop beeps but not all the time (Legion Y520 )
I have changed the RAM, the hard disks are OK (checked with a software), I have emptied the capacitors with the manipulation which consists in remaining pressed on the start button more than 1 min.
Thank you for your help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
When it beeps, how many beeps and is there a pattern to the beeps?
Does the laptop stop booting when it beeps?
Does the laptop work OK sometimes? If it does, try performing a diagnostics test on all the hardware to see if it shows anything.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
s.defigueiredo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 104
