跳转到主内容
Repair and disassembly information for the 2020 refresh of the MacBook Air model A2179 with an Intel processor that was released in March 2020.
103 个问题 查看全部
After I spoiled coffee, right speaker doesn't work.
The keyboard and left speaker are working, but the right speaker does not work and only makes a crackling sound. However, I don't know how to get the right speaker for the MacBook Air 2020. I ask for help if you can tell us where to get the right speaker part or if it is compatible with 2018 or 2019 model year.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Lee Hyun,
Here’s the guide to get to the speaker MacBook Air 13” Retina Display Late 2018 Right Speaker Replacement The 2018 model is very similar to the 2020 model with very few differences.
At this point I’m not sure if the uppercase changes between the 2018/2019 Butterfly keyboard to the newer 2020 Magic Keyboard altered the speakers. So far the availability of the 2020 speakers is only via Apple service. Here’s the older models part MacBook Air 13" (Late 2018-Mid 2019) Right Speaker If you had a sizable spill you might want to see if it will work.
You’ll need to get your system to an Apple authorized service center or if you can get to the Apple Store in Garosugil Seoul they should be able to replace the speaker hopefully the liquid detection tags didn’t get hit. That is if the speaker is different.
MacBook Air 13" (Late 2018-Mid 2019) Right Speaker图片
产品
$24.99
这个答案有帮助吗?
得分 1
2条评论:
Thank you so much for your advice!! But how did you know where I am?
完成的
I know a little Korean ;-}
Spent some time there in Soul and did a bit of traveling around.
完成的
添加一条评论
添加你的答案
이현재 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 93
