iPhone 11 pro not included
Hello, the phone is obviously dropped and does not turn on. what is its problem circuit board or battery.
If you did have vibrate on mute enabled, you can perform a quick and easy test. Simply flip the mute switch. If it vibrates then its obviously not the battery because it is powered on. You could also try to call your number. If it rings then again, it’s powered on. If you dropped it you most likely damaged the OLED panel.
这个答案有帮助吗?
Thanks for the info will work. ;)
过去的24小时: 1
过去的7天: 2
过去的30天: 13
总计 189
have you tried a replacement screen at all?
由 Jade Richards 完成的
I'm not I thought it was the battery
由 dimit1r89 完成的
