跳转到主内容
Nintendo’s first major revision of the 3DS released to Japan in October of 2014 and to North America in September of 2015. The 2015 3DS introduces improved 3D capabilities, a C-Stick, new internal amiibo support, and a new set of trigger buttons.
83 个问题 查看全部
My new 3DS volume is no longer working
I own a New Nintendo 3DS, never dropped it, never got it wet, always kept it in its case but I just stopped using it for a while. I decided to use it again and found that even if I move the slider, the volume stays super low. I’ve taken it apart properly to check if it was a slider issue but it isn’t. Is there anyway to fix it or is there a piece I can buy to fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@rsharky check the speaker ribbon cables and connector. You could try to connect a new speaker assembly (or for now just another speaker rigged to it) and see if that makes a difference. Also, check the audio jack and see if that works better/at all. If none of that works there is always a possibility that this is caused by a bad audio IC. Let us know what you find out with a new speaker first.
https://www.ifixit.com/Store/Game-Consol...
这个答案有帮助吗?
得分 1
2条评论:
@oldturkey03 I checked the ribbon and connectors there was nothing wrong with it. I don't have additional speakers with me. However, I noticed that even when I connect headphones in, the volume is still low. Also would that speaker assembly work for a regular new 3ds, not the XL?
完成的
@rsharky "that even when I connect headphones in, the volume is still low" makes me think that there is something else going on. Let me see if I can get some more info on the audio IC.
完成的
添加一条评论
添加你的答案
Rachel M 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 33
总计 878
