跳转到主内容
2018年7月发布,15英寸 MacBook Pro,型号 A1989,拥有True Tone技术的LED背光15.4英寸显示器,最高6核心的酷睿 i7 处理器。
147 个问题 查看全部
Issues after replacing swollen battery
Hi!
I recently replaced swollen battery on my 2018 15” MacBook Pro. After replacement there is a problem, sometimes charging adapter is not charging (the charging icon appears for a second and disappears), but this problem is not permanent.
The charging adapter starts working if I plug it to an other MacBook Pro, or after waiting for a while, or if an other charging adapter is plugged in.
Third-party service said that the problem could be caused with a faulty charging adapter and recommended to replace charging adapter.
I didn't replace the charging adapter yet, because I'm a little bit confused.
Please help me, what should i do? I don't know why my MacBook’s battery is swelled.
If you need more details, i can answer to your questions.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Did you check if the battery is plugged in properly? and if your battery is showing up in macOS? If it is then it most probably is a battery issue.
If it does not show up in macOS then you might need to open the MacBook and check the battery connection!
Do let me know what you find out!
这个答案有帮助吗?
得分 0
添加一条评论
There is a couple of things I would do here:
These will allow you to see more clearly what’s happening with your system. I do have a few questions which might offer us some clues on whats happening.
  • You talk about having access to a second system what is it? Is the charger the same or different?
  • Are you using the original charger and the USB-C cabe that came with it or using something different?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ilyasbek Isabekov 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 11
总计 144
