跳转到主内容
Known as the ''PS2'', it is a sixth-generation video game console first released by Sony in Japan in March 2000. The United States saw it later in 2000 with the SCPH-30000. Repair of this device requires only common tools, but can get tricky.
199 个问题 查看全部
Disk tray won’t close
I just received my dads old ps2 and the disk drive will open, but when prompted to shut it does so, then opens back up. It does this twice then just stays open.
i took it apart to clean it, and am hoping the problem will fix itself. Knowing it wont, what should i do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
I have the same problem I’ve been trying to figure out
完成的
添加一条评论
1个答案
已选择的解决方案
Hi Logan,
I saw this once as I had one which has this issue too.
I replaced the drive belt (replace this all the time actually), but at my case this was due the tray which was not seated properly. Could you check this? Perhaps you need to take it out, clean it and put it back in.
Note: Some models have additional screws installed to hold the disk tray at place!
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Logan Elias 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 43
总计 3,681
