跳转到主内容
Repair guides and support for your Samsung TV.
2610 个问题 查看全部
Samsung TV flickering and has backlight issues. what could it be?
I got this tv today the image flashes/flickers. it is a un65ks850df. it starts flickering after about 20 minutes or so of use. also it has a second problem that starts right when i turn it on. the backlight goes from high to low ( not gradually) every 30 seconds or so and it wont allow me to change the backlight level in the settings. however i am able to change the brightness and sharpness and contrast, just not the backlight. we sent it to a repair shop and he replaced the main board but it still does the same thing. This is a video of the tv flickering ( the most annoying problem). it goes away sometimes and comes back after a while. Please let me know what it could be. thank you
https://www.youtube.com/watch?v=zoIB7sGp...
this is a link of the flickering.
SHOW LESS
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Go to Menu , Picture, Backlight and vary level (0 – 20)
• If no backlight changes observed:
Check Panel Connector minus (-) pin voltages and P-DIM voltages while changing backlight level.
• If minus Panel voltages don’t change, and P-DIM changes, replace SMPS.
• If P-DIM doesn’t change replace Main/T-CON Board.
MUTE 4 1 9 EXIT to test Panel Backlight Sections.
这个答案有帮助吗?
得分 1
5条评论:
Thank you so much. So you do not think it is the LCD panel itself, or the backlights? Also, if i already replaced the main board, Is it safe to say it is the SMPs since you believe it is either that or the main board/tcon board? I dont have a voltage meter unfortunetely. This is my second time attempting to repair a tv but i could get one if you think it will be helpful.
完成的
Does anybody have an idea of whats going? could it be the panel itself?
完成的
No this would not be a back light issue or the LCD, if you follow the test above it will help you figure out which board it is.
完成的
Thank you again Brent! I will do the test tomorrow.
完成的
Just checking to see what you found out about this.
完成的
添加一条评论
添加你的答案
sebastien 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 22
总计 648
