跳转到主内容
Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
426 个问题 查看全部
I replaced the battery, and now it won't stay on
I’ve replaced the battery because it wouldn’t hold a charge. Now that I’ve put it all back together, I plugged it in to charge. Almost immediately, the apple logo comes on. That was expected. But after about 15 seconds, the screen flashes red and turns off. Then does this all over again. I’m afraid to leave it plugged in for fear of causing permanent damage. Has anyone had this issue before, or have suggestions? Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi,
Try to use the old battery to see if it turns on. It's also possible that you damaged the area around battery connector. Have a look, there are a few tiny components which you could've knocked off. Unfortunately red screen could also mean nand issues which would require reprogramming. If it's the nand it's not worth fixing imo. Probably cheaper to get another mini2. If it's a knocked off component it depends on how much you get charged to fix it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Duane Kesler 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 36
