跳转到主内容
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
212 个问题 查看全部
Ipad does not charge after a screen replacement
I did a screen replacement for a client and the part used are platinum rated. I followed the guide and I kept track of every screw and connector.
The device work flawlessly except from the fact that it does not charge anymore. It says sometime that it is charging, but it does not if you start analizing battery usage and a couple of minute after it realize that it doesn’t truly charge and start displaying the ‘‘none charging state’’ on the top right.
I don’t know what to do nor how to solve that problem.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
hello there,
it’s depending what you did, which part you changed before.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mobileklinik st bruno 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 41
