跳转到主内容
The GameCube is Nintendo's fourth console gaming system. Repair is simple and requires only common tools.
91 个问题 查看全部
Half of my games freeze when they are read?
Hey!
I recently bought a Gamecube off of a seller on eBay. The seller said the system was working fine, but I ran into issues with it the other day. Some of my games, like Mario Sunshine, TTYD, and Melee all work fine without any problems, but my other half of games seem to be read and then freeze at the loading screens.
Super Monkey Ball 2: Stuck at the “Presented by SEGA” screen, doesn’t play any sound.
Luigi’s Mansion: Will load to the title screen, but when the intro cinematic plays after a while, the picture freezes. The audio continues to play without issue.
Mario Party 7: Reads the disc then is just stuck at a black screen, also doesn’t play any sound.
I’ve tried booting these games up with no controllers or memory cards inserted, doesn’t work. Pressing the reset button while they are frozen does nothing. I’m pretty stuck here, I haven’t really found this specific problem anywhere else online. Thank you for reading.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@pkbrandon “seem to be read and then freeze at the loading screens. “ could be caused by a dirty laser lens. Use a commercially available laser lens cleaner and see if that works. If not you may have to disassemble it and clean it or you may even have to adjust the lens power (careful with that since if not done right by burn out your laser :-) Nintendo GameCube Optical Laser Lens Replacement
Optical Laser Lens Power Adjustment
Nintendo GameCube Optical Laser Lens图片
指南
难度:
中等
30 - 45 minutes
Nintendo GameCube图片
指南
难度:
中等
30 minutes
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brandon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 364
