跳转到主内容
Unveiled at the 2000 North American International Auto Show on January 10, 2000, the redesigned 2001 Dodge Caravan and 2001 Chrysler Town & Country were released for sale in August 2000.
179 个问题 查看全部
gear lights are all on and wont shift properly
i hooked it on the tester and got codes p1698 and p0500 any advise
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Research shows that these are errors related to your computer and transmission not talking properly. In particular, your p1698 code is the tranny and computer not talking and your p0500 code is "no speedo signal" . The easiest/cheapest thing to replace/check is the cable running from your power control module to your transmission control module.
Unfortunately I can't find much on finding or tracing that wire...but I'm sure if you stop into your local auto-parts store you can find a manual, give it a quick read and memorize what you need from it!
Check out this link, it has some description of the PCM and TCM locations.
这个答案有帮助吗?
得分 2
1条评论:
+ totally agree....david you can download the service manual modules from here. let me know if you need more info on those. Good Luck.
powertrain and transmission
完成的
添加一条评论
添加你的答案
david 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 3,783
