跳转到主内容
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
281 个问题 查看全部
"No Battery Available" and dies when it is unplugged
I replaced the battery on my 2015 A1534 MacBook as the battery life was getting very bad. The replacement went smooth and the laptop was working just fine. About a week later, when I woke up this morning now the laptop is showing an X through the battery icon and in greyed out letters it says “No Battery Available” . When I unplug the computer the screen fades to black and the computer becomes unresponsive. If I plug it in within a couple seconds the computer will come back on, otherwise it will fully shut off and I have to plug it in and power it on again. I tried a SMC reset but I am still having the same issue. I am using the original cable and original power brick.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Where did you buy the battery?
If its an iFixit battery you will need to contact the store to get a replacement under warranty! Contact iFixit Customer Support
这个答案有帮助吗?
得分 0
2条评论:
Was not purchased through iFixit. Sounds like you believe that it is a issue with the battery itself then, any reason why you think that specifically?
完成的
I think the system is telling you the answer here "No Battery Available"
完成的
添加一条评论
添加你的答案
Indian Intern 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 44
