跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Can I transfer the motherboard in my iPhone 5?
My iphone 5 case is severely damaged, but the unit still works. I want to keep the motherboard to keep apps that I use but are no longer available. I’m assuming that all functionality is in the motherboard… I’ve reviewed the ifixit instructions for changing the motherboard and it seems very doable. I have another iphone 5 that will serve as the new frame ‘donor’ after I remove that motherboard.
Any advice from anyone who’s changed the motherboard appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You can absolutely swap the board to a new frame. Just make sure you keep yourself organized and take your time. Thankfully the iPhone 5 is pretty simple in design compared to newer models, some of which require other parts to be transferred in order to maintain certain features.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kevin Knoop 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 19
